Just a quickie - I need to move the car off the drive each morning to get a van on the road.
Apart from the probably undesirable consequences of starting the engine, and moving the car 10', should I wait for the suspension to rise/fall/do whatever it wants to do before driving off? The font of the car almost leaps up on the first few revolutions of the engine, followed by the rear sometime later; not sure how long after, it's much more gradual.
Secondary question while I think about it - is the Xantia nickable? I mean to say, should I be concerned about it's theft and religiously fit a steering lock? Is the alarm enough?
Cheers dears
Xantia - let suspension go up before driving off?
Napoleon
- x 4
Tim
2009 HV09 C5 2.2
1996 N679 Xantia TD VSX estate - sold August 2012
1995 M289 Xantia TD SX hatch - sold March 2012
Tarte au Citroen
2009 24" iMac 3.06GHZ
2009 HV09 C5 2.2
Tarte au Citroen
addo
- Sara Watson's Stalker
- x 95
Ross_K
- x 110
Re: Xantia - let suspension go up before driving off?
Is it nickable? As in would someone bother nicking one? Or as in "is the built-in security enough"?Napoleon wrote:Secondary question while I think about it - is the Xantia nickable? I mean to say, should I be concerned about it's theft and religiously fit a steering lock? Is the alarm enough?
Cheers dears
Someone would be doing me a favour nicking mine, but it doesn't have a keypad or fancy transponder immobiliser like the later Xantias. Short of leaving the keys in the ignition for a week I can't any toerags making off with it, specially as scrap metal prices have gone through the floor again. 8)
Save your steering lock money for a few pints at the weekend.
- x 1238
handyman
- x 1238
Xaccers
- x 185
And with 816 miles from a full tank'd 1.9TD surely you can out range most police cars (albeit by driving very carefully - roads with lots of speed bumps should help)
DIY sphere tool
DIY sphere tool
Exhume.dk
- x 3
red_dwarfers
- x 58
Watching Top Gear on Sunday I really think one of them should have used a 1.9/2.1 Diesel Xantia for the drive to blackpool, 800 to the tank easy!Xac wrote:And with 816 miles from a full tank'd 1.9TD surely you can out range most police cars (albeit by driving very carefully - roads with lots of speed bumps should help)
Kev
'19 C4 Cactus 130 Flair
Xaccers
- x 185
I was thinking the same too!red_dwarfers wrote:Watching Top Gear on Sunday I really think one of them should have used a 1.9/2.1 Diesel Xantia for the drive to blackpool, 800 to the tank easy!Xac wrote:And with 816 miles from a full tank'd 1.9TD surely you can out range most police cars (albeit by driving very carefully - roads with lots of speed bumps should help)
As for the 3cylinder VW getting 80mpg, I'm sure I've read about the AX 1.4D getting similar mpg too.
DIY sphere tool
DIY sphere tool
reblack68
Xaccers
- x 185
100mpg according to Wiki!In 1989 a naturally aspirated diesel AX, using the 1360 cc all aluminium alloy TUD engine, managed a figure of 2.7 litres per 100 kilometres (100 mpg-imp/87 mpg-US), totalling over 1,000 miles (1,609 km) from Dover to Barcelona. This was the longest ever distance travelled on 10 imp gal (45.5 L/12.0 US gal) of fuel and earned it a place in the Guinness Book of Records as the most economical production car.
So nearly 20 years later, and with a direct injection diesel and all the technological advances since then, that VW got up to what? 70mpg?
DIY sphere tool
DIY sphere tool
Toby_HDi
- x 3
Again, a HDi would have done that top gear challenge too. I've had 700 from a tank and that was not driving economically.
Xac, with regards to your comment about VW not matching an AX. I believe the problem lies with modern cars being much heavier and bloated. Blame all the extra impact regulations they have to adhere to these days. A safe car is nice yes, but surely it can be done without adding obscene amounts of weight to a car. All the extra equipment doesn't help either (though I do like my gadgets
Just not like older cars where you got a box on wheels, an engine and not much else.
Xaccers
- x 185
Thing is, the TUD3 was only 52hp compared to the TDI which is either 70 or 80.
AX kerb weight is 725kg
Polo kerb weight is 990kg
So the increase in mass in proportional to the increas in power (no idea if that actually makes a difference, but it sounds good)
DIY sphere tool
DIY sphere tool
Toby_HDi
- x 3
Hmm true. I guess what we really should be looking at is power to weight ratios??
AX 725kg with 52bhp
VW 990kg with 78bhp
AX = 71.72bhp/ton
VW = 78.79bhp/ton
Quite similar actually so yes, it is proportional.
Therefore I could be cynical and say its all an elaborate ploy to make sure we are using more fuel and hence pay more money......
.....no? Just me then
AX 725kg with 52bhp
VW 990kg with 78bhp
AX = 71.72bhp/ton
VW = 78.79bhp/ton
