It appears the rear suspension additives all mount to standard trailing arms (by part number) but use some extra holes in the subframe (is it stiffened there?). On the front, at least the strut base to which the ram is attached, is different to non Activa - is the opposing side different to stock?
Also it seems the lower front arms may have a different part number - is it a larger pivot bearing/bushing to account for extra stresses?
If (run for cover now!) one were to fit the Activa antiroll bars and so forth to a vehicle and not (yet) integrate the system could the rams simply be filled with fluid and capped off, to create more or less rigid links? I assume they're bidirectional in function, like the PAS ram.
Would the rear ram top, hit an estate boot floor?
Thanks, Adam.
p.s. I see the Activa ECU (as opposed to the Hydractive II) is now "NFP".
