1998 megane scenic plip key problem
meerchant1
Unread post by meerchant1 »
hi my first post :lol:
my problem is that i have a 1998 s reg renault megane scenic 2.0 automatic...the plip keys were working.until the batteries run out on one of them.and i replace them on both keys..now only one key will remote unlock the doors....i have followed various posts and links on this forum
but when i push the button on the keys the light goes out after 3 second
and i have followed all the instructions and it still will not sync up with the
car.....any advice please
regards
graham winn
Unread post by graham winn »
have you mannually entered the 4 digit code using the door unlock button on the dash and counting the red light pulses,
if so after that the car should start!
now its time to syncronise the key to the ecu turn off the engine leaving the ignition on
push door unlock button & keeping finger on button & pushed in,
remove key hold key towards mirror and repeatedly push remote button untill the doors unlock and lock good luck!! [email protected]
meerchant1
thanks for the reply.i will try it now and let you know.thanks
meerchant1
:twisted: still having problems with these keys :(
one works perfect the other nothing..h :( eres the steps ive followed..if ive done anything wrong will some one please let me know..
locked the doors with the working key,so the immobiliser is on..
1 unlocked the door by key manually
2 turned ignition on so dash lights come on
3 pressed and held the door lock button on the dash for 5 seconds sometimes 10 seconds and nothing. no light no flashes..
what am i doing wrong.
meerchant1
:D solved at last :D
1st check your key is working properly,dont go by the red light :D hold key in front of modile phone camera and press the button, it should show
bright blue ....if it works the lets proceed... :D
2nd download this little program from here
Code: Select all
http://renaulthelp.110mb.com/ImmBypass.html
the instruction are on the site but i will write them here..
get your car model number FROM your id plate on the door pillar
get your key number from your paperwork or from inside the key,,my one was stamped on the plastic cover not the board..
now you should have a 4 digit code...
Get into your car, switch on the ignition and hold the central locking button down and the red immobiliser light will start to flash slowly.
Count out the number of flashes and release the central locking button when it matches the number of the 1st digit of your bypass code.
Now hold down the central locking button and count the flashes up to the 2nd digit of the bypass code and release.
Repeat the above step for the 3rd and 4th digits.
ie:: hold button 2 flashes,release ,hold button 5 flashes,release ,hold button 1 flash,release ,hold button 1 flash,release
gives you code of 2511
Re-synching the key fob (may not always work):
With all bypass digits entered, turn off the ignition.
Hold down the central locking button. The immobiliser lights should remain constantly on.
Point your key fob at the IR sensor near the internal rear view mirror and press on/off quickly. Hopefully the key should now be re-synched.
:D
sparky33
Unread post by sparky33 »
You only have 15 seconds to replace the battery, after that the key loses it's memory and cannot be reprogrammed, you will find info here www.coupe-club.org.uk
