ZX Heated Rear Window
JohnStuart
The heated rear window on my sons ZX will not come on when the switch is pushed. The switch fails to light up but a click can be heard when pushed. The connectors to the rear screen appear to be intact as is the screen but a meter is not showing any voltage being applied on the connectors. The fuses have been tested and seem good.
AndersDK
John - it seems fairly obvious that you (your son) are facing an instrument panel tear down tracking the missing 12V supply to both the switch lamp & the rear screen. The switch lamp MAY have a burned bulb.
If lucky<img src=icon_smile_evil.gif border=0 align=middle> - you may trace the problem down to a bad relay (the one you can hear clicking) or a loose fit connector on the switch/relay/fusebox.
C U
Anders(DK)
C U
Anders(DK)
Jon
The HRW switches also fail on the ZX.
We used to sell a few of them here and when I worked at a Dealers.
Seem to remember theres a change at about RP6171.
The other thing to check as Anders says is the relay, its a timer relay on these to prevent the HRW being left on too long, they have been known to fail in the past.
Jon Wood
Forum Admin
Jon Wood
Forum Admin
MW
I don't know the model, but it would be sensible to start with a simple continuity test from the fuse box (with fuse out) to the heated rear window. You don't want to rip the dash apart and then find that it's just a cracked solder joint at the window end of the wire, do you? It's always sad to see grown-ups cry. [:D]
Mike
Mike
