xantia front suspension
paco
Unread post by paco »
hi
the advisery note from my sons last mot stated that, the front upper suspension rubber joints are slightly worn.
i cannot find any reference to this in the haynes.
i mistakenly replaced the drop link arm, to no avail.
could someone clue me up on this condition and the solution too it.
regards
barry
x 8403
Sounds like he means strut tops.
Very serious, especially if an MOT tester has made a remark..
See this for the full low-down on failing Strut Tops.
It's long and can be disturbing in parts. Sit down before reading!
If they are showing any signs of distress at all, replace ASAP.
paco
o
thanks for the reply, sounds like the stut tops,what do i need and where do i buy replacements at a decent price.
reards
barry
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Barry - only Citroën make the replacements. I think the cheapest anyone got them (albeit with a little "squeezing" of the counter dummy) was £109 each, but can't remember if that was plus or inclusive of VAT.
I do recall the big thread exposed how varying dealer prices could be.
Regards, Adam.
x 8403
Strut tops are a dealer only part. Quite expensive as well at around £100 per side. Hydractive and non-Hydractive ones are different and not interchangable.
Xac will shortly come along with a cautionary tale of apparantly good strut tops in a scrapyard that proved, on examination, to be anything but.
For peace of mind, always fit new ones. The actual job of fitting is dead simple, one of the easiest jobs on a Xantia :D
Xaccers
x 188
Unread post by Xaccers »
If you're lucky like me, you'll get one for about £95 inc VAT :D
Would have gotten both at that price but they ordered the wrong one.
Basically they hadn't got the price on their system right so charged me cost.
They then realised that after I took the wrong one back and charged me the proper price (minus a little).
As Jim said, I spent ages trying to get what we thought was a good strut top off a scrap car (the car was flat on the ground which was why it was so difficult) only to find it was rusty as hell and actually popped when I discarded it into the engine bay!
Having said that, the ones we took off Cassy are still in good condition, only starting to lose the rubber edge in one place, so Jenny will get them, and plenty of waxoyl etc.
DIY sphere tool
x 94
Unread post by citronut »
do not use wax oil on ruberised components, as this will be of detriment to the rubber,
also i bought a pair of new strut tops from the dealer at £117 each incl the VAT trade
regards malcolm
Xaccers
x 188
I normally use silicon based greases on rubber, although would the strut top actually be rubber or would it be vitron?
DIY sphere tool
paco
thnak you all for your reply's , i will put it through an mot and see what we see.
regards
barry
steelcityuk
Unread post by steelcityuk »
Here's a photo of a severely corroded strut top on a XM I bought.
Steve.
not applicable
