wet footwell
telderv
wet footwell
i have an o2 laguna II, while driving this morn a puddle apeared in the passenger footwell, only about a cup full but it has come from behind the dash and now the blower for the heater has packed in, anyone got any ideas where its coming from and how to stop it?
LAGUNA II 1.9DCI DYNAMIQUE
ACTIVE8
- x 6
telderv
ACTIVE8
- x 6
telderv
ACTIVE8
- x 6
ferkemall
- New User
Re: wet footwell
Its a Renault they designed that way the short one is the bulkhead water drains block up , i took a pair of cutters to the flaps they put on them because they cause the problem , water runs down inside the dash shorting stuff as it goes then runs down the fuse/relay box under the bonnet and shorts that out ,
I checked my fuse /relay unit it was ok so got some spray silicone and did the inside with that then got some clear spray wax and did the fuse/relay unit and the water runs on the bulkhead ,had the car [ modus ] 2 years everything still works !
