Xantia anti-roll bar bushes
hirsty
x 9
Unread post by hirsty »
The front bushes are starting to clunk over bumps and need renewing. Is this straightforward ? The BOL mentions removing front height corrector and main stealer resetting. Is this necessary ?
98 Xantia Mk2 2.0 16v Auto Exclusive 160k + Now gone to Citroen Heaven
2004 C5 Mk 1 2.0 8V VTR Estate - current. Now with leather.
x 94
Unread post by citronut »
it is more than likely the drop links not the anti roll bar bushes, and as long as you have new nuts with these it is quite straight forward, because if you cant undo the nuts you just lopp them off with an angle grinder,
no need to go anywhere near the height correctors
regards malcolm
hirsty
x 9
Drop links renewed two weeks ago. Still clunking.
john alexander
Unread post by john alexander »
Hi hope someone answers this quick as mine is exactly the same . regards john.
x 8391
ARB bushes are generall pretty long-lived. It's unlikely they have failed to the extent they cause clunks.
Have a good look at your lower swivel joints and your wishbone bushes, both the "P" bushes on the rearward side of the wishbone and and the more ordinary bush on the opposite side.
If they're OK, the ARB bushes I believe can be changed with the bar in-situ with a bit of fiddling. You may need to drop the subframe a tad.
I've replaced them on Pugs like this and the Xantia is pretty similar in this area.
hirsty
x 9
Got the car on a workshop ramp today and checked all possible joints. The last thing looked at was the new drop links and one of them has failed already. Now I'm wondering if it was ever replaced or just new nuts put on to make it appear new.
john alexander
Hi It was the drop link on mine as well , just convinced myself it was the drivers side that was knocking and never checked the passenger side DOH John.
