Well as the title says, it's 6AM and the alarm on my son's Peugeot 206 has just got me up again, (well he's 18 and wont here anything untill mid day)
And all this on a morning when I was looking forward to grabbing the extra hour granted in bed, I was up for a call out at 2.30 and back in bed at 4pm so the hour would have been welcomed.
Enough of the rant I hear you say, what does he want to know??
This alarm is a frequent offender and I would like to get rid of it forever, as nobody takes any notice of car alarms anyway.
I have told him over and over again, lock it using the key and the alarm will not set, but being 18 he is either too lazy or forgets and uses the remote.
Is there any way to shut it out of my life permenent, or at least silence the siren, on the older Xantia, there used to be a switch under the bonnet where you can put the ignition key in to disable the siren, I cant see anything on this car?
The offending car.... Peugeot 206 Quicksilver 1.4 reg 2004
Thanks in advance.
Martin.
The 6AM Alarm, Peugeot 206. How can I get rid of it??
Pleiades
- x 8063
It's the ducks flying around the car at dawn Martin!
I reckon it'll be the volumetric (ultrasonic) movement sensors causing this. They often start to throw up sprurious alarms as they age. Very common on Xantias.
Somewhere you should be able to set the alarm with them defeated. Normally a button you press until the red alarm LED comes on permanantly. Then, when you set the alarm, the volumetrics will be out of the equation and your sleep should be undisturbed.
I've no idea where the button is on the 206 but it should have roughly the same symbol on it as the Xantia has, a sort of loudspeaker symbol with a cross through it. Press this with the ignition off until the LED that normally flashes lights up solid and then set the alarm.
Pleiades
Morning Jim.
I see that you are not taking advantage of the extra hour?
You may be correct about the ducks! Several mornings I have been out and seen webed footprints on the roof of cars parked out the back.
I will have a look and see about the sensor switch, but dont you have to do this every time the car is locked rather than once and for all?
I am looking for something permenant (burn the car) snip the wire to the alarm siren? or maybe this will upset the immobilisor?
Regards
Martin.
Regards
Martin.
- x 8063
Noboby thought to tell the dogPleiades wrote: I see that you are not taking advantage of the extra hour?
Yes, every time you set the alarm. Also, if you set the volumetrics to defeat mode, it'll time out after a few minutes as well.Pleiades wrote: ...but dont you have to do this every time the car is locked rather than once and for all?
If defeat of the volumetrics work, that's the problem and replacement will solve it totally but they're quite priey and the door cards have to come off to change them
Trouble with snippping the siren is that the alarm will still activate and flash the lights. I wonder if disconnecting the volumetric sensors will do the trick of permanantly defeating them or is the alarm clever enough to know they've been tampered with? Resistors might do the trick though.
The alarm and immobiliser are normally totally separate things. On the 206 I expect the immobiliser works from the RFID chip in the key and the "plip" part of the key activates the central locking and alarm.
Don't burn it Martin! In discussion with my 16 year old daughter yesterday, that's just the car I'm considering getting for her when she starts driving. My first choice of a Saxo/106 was rejected by her as being too "chavvy"...
reblack68
I asked about this for my old Xantia and was told that the alarm could be switched off by connecting to a dealer's computer. I'd imagine it's the same for the Peugeot. Obviously there are insurance implications, but IMO no car has ever been saved from theft by its alarm.
Do you have a trade contact who could do that for you?
Richard
Care of a 1994 205 D.
DickieG
- Monaco's youngest playboy
- x 38
That's true for S2 Xantia's, you need a Lexia to re-programme the CPH unit, so I presume it can also be done on a 206.reblack68 wrote:I asked about this for my old Xantia and was told that the alarm could be switched off by connecting to a dealer's computer. I'd imagine it's the same for the Peugeot.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Homer
- x 16
Re: The 6AM Alarm, Peugeot 206. How can I get rid of it??
Then every time it wakes you, take a bucket of ice cold water and throw it over him in bed.Pleiades wrote: This alarm is a frequent offender and I would like to get rid of it forever, as nobody takes any notice of car alarms anyway.
It will help his memory.
Pleiades
I like it, maybe I should let him read this first as a warning? Or there again, maybe not.Homer wrote:
Regards
Martin.
LukeMeister
This is the button in question (bottom button next to handbrake). Hold it down for a couple of seconds until the alarm LED stays lit and the ultrasonic sensors will be de-activated.citrojim wrote: Somewhere you should be able to set the alarm with them defeated. Normally a button you press until the red alarm LED comes on permanantly. Then, when you set the alarm, the volumetrics will be out of the equation and your sleep should be undisturbed.
New sensors are in-expensive at £23.50 (part number 6680E9). A DIY fitting guide can be found here.
- x 94
citrojim wrote:Noboby thought to tell the dogPleiades wrote: I see that you are not taking advantage of the extra hour?![]()
Yes, every time you set the alarm. Also, if you set the volumetrics to defeat mode, it'll time out after a few minutes as well.Pleiades wrote: ...but dont you have to do this every time the car is locked rather than once and for all?I'm into the habit of doing it on my Estate now because the volumetrics are dead and I'v not got round to swapping them yet
If defeat of the volumetrics work, that's the problem and replacement will solve it totally but they're quite priey and the door cards have to come off to change themI hate disturbing door cards - hence why mine are not yet fiixed!
get your daghter a dersh, then you will be able to get the test drive you long for
regards malcolm
