Sorry if this has already been asnswered but i can't get the search to work for some reason at the moment.I am considering fitting an HID conversion. The reason for this is I travel 58 miles each way to work and most of it is on unlit roads, now the clocks are going back I don't fancy another winter with poorish lights. I have fitted Osram Nightbreaker bulbs but on dip I could still do with more light. High beam is fine but can't use it much because of oncoming traffic. Now I know fitting HID units are technically not legal, BUT one thing I noticed on the DOT site, was that it said they must be fitted to headlamps that are self leveling or the car has self leveling suspension. I would assume that with the Xantias suspension, is classed as self leveling? If that is the case I should not dazzle people like I would with a conventionally set up car and then my only "crime" would be that the units are not E marked as an assembly.
Has anyone fitted these units and what problems have you had.
Thanks,
Garth
HID conversions on a Xantia
XantiaMan
- x 18
~Yes thats correct, as the suspension always maintains the height, the headlights do not need to be self-adjusting, although they would obviously need setting up properly in the first place. I'm considering an HID kit, mainly just to p**s off BMW's and Merc's 8)
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
2017 Fiesta ST
- x 8417
Xaccers
- x 188
Also check that your headlamp alignment isn't too low, on most Xantias I've driven they are, and pointing them up a bit makes a vast improvement without dazzling oncoming drivers.
DIY sphere tool
DIY sphere tool
JohnD
- x 72
addo
- Sara Watson's Stalker
- x 95
uncle buck
- x 10
Yes that's correct.JohnD wrote:For HID lamps to be legal don't they also have to have washers fitted?
My Laguna has Xenon headlights (factory fitted) & personally I think they are rubbish....in my opinion they don't light the road any better than standard Halogen lights.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
DickieG
- Monaco's youngest playboy
- x 33
As Jim states try the relay conversion before splashing out on HID's, I did it on what is now Jim's Activa and the improvement was significant, the lights went from yellow to white 8)
As a quick test connect a voltmeter onto the wire running into the back of the headlight and compare the reading with battery voltage, I bet there's a difference of at least one volt which has a significant effect on light output.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
lexi
- x 133
Don`t know about the Xantia but I always uprated the wiring from Relay to headlight. On a lot of vehicles it is thin and power is lost .
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
lolingram
- RIP 2010
Quite so. The mod gave me (with engine running) 14.2v at the bubs instead of 12.3v. Needless to say Xant headlamps are NOT relayed. Difference is very significant. It aslo is worthwhile running HD earth leads from the lamps direct to the chassis earth block next to the battery.No need of HID on a Xantia..
Just do the headlamp relay mod and you'll be flabbergasted by the improvement.
The mod, combined with good bulbs like Osram Silver Stars, really does make all the difference Very Happy
_________________
The bulbs are icing on the cake - good but expensive.
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
jgra1
- (Donor 2021)
- x 36
HI Addo, whilst the S2 cars seem brighter, the wiring increase makes a good difference still..is it reasonable to assume that the second generation had headlight relays fitted as delivered?
Lol I thought all cars have relays as standard, just thin wires running to them?
anyway, I did the conversion, cost me about £10 in parts, and fairly straightforward..
Will follow Jims advice and make my bulbs better now too
My beams are mis-aligned due to a bad adjuster
John
