xantia outside temperature sensor location
bradspau
Unread post by bradspau »
My outside temperature gauge shows flashing -- -- rather than the temperature. Where is the temp gauge located?. I am assuming it is in the drivers side door mirror as this has been replaced previously, before I owned the car. If this is the case can the sensor be purchased seperatly or only with a complete door mirror assy?
thanks
x 8391
In the MK1 its in the drivers door mirror. On the MK2 its in the passengers side...
If you feel underneath the mirror hinge, you'll feel a little bump if the sensor is there. It's just a thermistor.
ACTIVE8
x 6
Unread post by ACTIVE8 »
citrojim wrote:In the MK1 its in the drivers door mirror. On the MK2 its in the passengers side...
So why did it swop sides?
ACTIVA
marsalek
x 19
Unread post by marsalek »
Due to weight balance!
Karel
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
I didn't think it did change sides.... did it??
I was under the impression they were all on the passenger mirror... Ill do a check on that, I have a S1 VSX here and a S2 Exclusive too...
Interesting .......
A very sad...
1994 XM 2.1 d auto
deian
Unread post by deian »
marsalek wrote:Due to weight balance!
Karel
You are joking right? The weight of a temp sensor wouldn't be an issue in weight balance.
Isn't that a silly place to put a temp sensor? Wouldn't wind chill factor affect it? And sun shining on the mirror warming it up.
BMW's have them inside the front bottom bumbper in the corner, no wind factor to affect it, no sun shining on it, and lower to the ground, therefore quicker to register freezing temps on the road surface. It's not that exposed to the elements either as it is tucked on the inside.
citroenxm
Fallen Hero
x 70
Lighten up a bit.... he could be having a laugh! 8)
The sensors ARE in the mirror, and I've never experianced them having wind chill problems, or heated mirror syndrome affecting them...
Paul
A very sad...
1994 XM 2.1 d auto
x 8391
The change of location could be to do with the location of the gauge. In the MK1 it's in the Tacho whereas in the MK2 it's in the dash over nearer the passenger side along with the clock.
Therefore, less wires, cheaper looms :lol:
Although that would only be true in a RHD car :?
Paul, no, I've not seen a windchill problem but if you park up so that direct sunlight is striking the mirror body in summer, you can see some pretty wild readings until you get moving :roll:
I've seen mine saying 50 degrees! Global Warming :lol:
