Hi all
I have a 2000 V xantia sx hdi with an annoying problem.
The car feels sluggish and every other day it will go into limp home mode and the management lamp comes on. After a stop/start it seems to clear then after a while the lamp goes out.
The whole cycle then repeats after a few days.
I had the faults read which was the ECU but Im reluctant to remove the connector to check for corrosion in case its irrepairable?
Any ideas ?
Many Thanks
xantia engine management lamp / loss of power / limp home
kr1s
TBONE
DickieG
- Monaco's youngest playboy
- x 38
The most common cause of such faults (limp home mode on HDi's) is a build up of gunge/faulty solenoid on the turbo boost/EGR vacuum pipes which are located close to the O/S/F suspension strut. Pull the pipes off and try giving them a blow through and make sure you put the 'T' piece back together the same way as it was removed as the hole on one of the ports is much smaller to restrict airflow. Citroën issued a service bulletin on this as it is a common occurrence.
I also had a similar fault code (faulty ECU) generated on my HDi which wouldn't clear in the usual way (even with my Lexia) until I used the Lexia to reset the ECU (a different procedure).
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
kr1s
