When I removed the head, the engine was set to align the locking bolts. I've since removed the head and lost the camshaft/valve position. I think the Haynes manual can help me there but I haven't studied it yet, it's in the car. Anyone know a quicker way?
I think there's a photo of how the pistons are but like I said, they're at the position needed to lock the pulleys etc - both outer pistons up, middle two down.
Camshaft & Valve positioning
Xaccers
- x 188
For Cassy, we removed the cam from the head, timed the pump and crank, then re-fitted the cam using the timing hole and bolt.
DIY sphere tool
DIY sphere tool
MikeT
- x 232
- x 94
- x 8396
Mike,
I would also check the crank is in the right position. As said, with the cam and pump, you cannot go wrong. Line up the timing holes and job done.
I may be talking rubbish here but when I last did a cambelt on a TU engine I had to retime it from scratch. I found the flywheel had four timing holes in it, 90 degrees apart
I'm not saying the XUD is the same but I have a nagging feeling it does have at least two. I recall needing to find the hole on one occasion and was surprised to find one where I did not expect it to be.
Have a look at the cam and it's relationship to valves when it is timed up and check the pistons are in the right places.
It will be very prudent to spin the engine gently with injectors out after the head goes back on just to check the timing is right. If it comes to a metallic stop at any point in its rotation, it's wrong!
Malcolm, that's a good tip to have the pistons just off TDC when initially fitting the head!
TBONE
- x 8396
MikeT
- x 232
Some good suggestions there, thanks for the prompting and I certainly will lower the top pistons first. I just wanted to get the right angle dangle of the valves first as it'll be a might difficult if I'm in the wrong quarter when it's bolted down.
But I'm a long way of timing the belt yet, I've had a few setbacks today but I'll update the blog once I've gotten my dinner.
TBONE, I'd be most grateful, expect a PM shortly.
TBONE
not sure if this will work but worth a try
http://www.flipdrive.com/flipdrive.php
edit* nop that was a fail
- x 94
the cranck is nay a prob even if there is more than one pin hole????,
you can get it almost spot on by whatching the sprocket end woodruff key when it gets to about 12 oclock, just set it so the rear edge of the woodruf key is in line the front edge of the small raised block in the castting just above the crack sprocket, then you will find you might just have to rock the crank very slightly to locate the timming pin in flywheel,
easy peasy
also NEVER NEVER SPIN ENGINE WITH STARTER TO CHECK IF YOU HAVE ANY CONTACT BETWEEN VALVES AND PISTONS,
ALWAYS TURN GENTLY WITH A SOCKET ON CRANCK PULLY BOLT TWO COMPLETE TURNS, AND NEVER FORCE PAST ANY TIGHTNES
regards malcolm
easy peasy
regards malcolm
MikeT
- x 232
TBONE
- x 8396
MikeT
- x 232
