A success story.
I browsed on here and found lots of references to the speedo sticking at 50mph/80kph.
The remedy was to remove the instrument cluster and solder some pins.
Well I managed to remove it all but my PCB didn't match up. But I could find 4 similar pins and with a magnifying glass did see some slight damage to one of them.
And it now works!
It took me 3-4 hours to remove, fix and reassemble and I don't really have a clue.
If I can do it then anybody can.
I can't quite find the links anymore but there was a link to a blog on how to do it. It didn't match 100% with what I found but it was helpful enough to allow me to get it done.
This is a really annoying fault that could cause somebody to get rid of the car, what with speed cameras etc so hopefully others will try this fix too.
Thanks!
sticky Xantia speedo fixed
- x 8395
3ps
Thanks.
Found the links:
http://www.frenchcarforum.co.uk/forum/v ... c&start=15
http://www.schaalbouw.nl/citroen/blog051007.htm
Found the links:
