Laguna Electrics
jpawson74
Laguna Electrics
Unread post by jpawson74 »
Since I had a flat battery which I removed and recharged I have been having trouble with my electrics. The heater blower no longer works on any speed even though all the lights light up and you can hear the air con click on etc, is there a fuse or relay for the blower? Also when I raise my drivers side window the stereo cuts out and then resumes when I let go of the button. Any advice would be appeciated.
Laguna 1.9 cdi expression 03 plate
jpawson74
update, went out to car today and I now have a flat battery again
TBONE
Unread post by TBONE »
you have an earth problem check all the ground wires
jpawson74
thanks for your reply, it's going into the garage tomorrow so i'll suggest the earth, also the stereo cuts out when I put my wipers on, weird
jpawson74
The blower had failed replacement at £155, and needed new battery which was causing the stereo problems due to poor contacts
