Jenny has one.
Despite the new clutch (I believe before she was with Craig), it's very heavy and I have to put my foot to the floor to properly change gears.
How do these cables actually work?
Do they need "resetting" when a new clutch is fitted?
The pedal sits at the top of it's swing, and there's nothing for about an inch of movement before you feel anything.
Self adjusting clutch cable
Xaccers
- x 188
DIY sphere tool
DIY sphere tool
- x 1488
It's got a sort of sliding ratchet arrangement in the outer cable. I think it should let go and slacken off when the load is released (ie cable disconnected), then re-tighten the first time the clutch is pressed. You might be able to 'wake' it up by letting the clutch pedal bang up a couple of times (or you might just break the clip
) However, if it's still heavy after clutch change then it's new cable time - but that involves access to the dreaded clip - how's your back???
- x 8391
Not Xac's problem. It'll be mineRichardW wrote:then it's new cable time - but that involves access to the dreaded clip - how's your back???
Is it possible to replace the self-adjusting cable with a non-self adjusting cable?
