citroen c5 - Tailgate window will not open
carebear
Unread post by carebear »
the window used to open, but won't now, is this controlled by the central locking system. when you press the button on the window to open it you can hear click can anyone help me with this please.
den169
Unread post by den169 »
Seems a common fault on the c5 estate mines the same,Theres a guy on ebay selling instructions on how to fix this for £14 i think it was however i found it on the net with very good pictures and full instructions.Apparently its a bad earth and you have to take the trim off the door to get to the wires and fit a new earth wire etc.Iv'e had the panel off the bottom of the door and that lets you get to the lock mechanism you can open the glass door from there.Iv'e not had time to do it yet but let me have your email addy and i'll send the instructions to you.
x 5674
It is a very common problem but easy to fix, especially if you let someone else do it, as I did.
The guy fixing the climate control did it while he was here. Took him 10 minutes.
