xsara steering wheel alignment
jimbow
credit crunched from a series 2 xantia activa to a 1.9D X Xsara ((X reg with just over 100k recorded). When the wheel is set "dead ahead" the car veers ever so slightly to the left. Is this the consequence of "wear and tear" (e.g. not unusual/ they all do that) but ok to postpone adjustment until next service ?
- x 94
its usualy eithersomeone has adjusted the tracking one sided (incorect), or the steering wheel has been removed and re/fitted one or to splines out,
the easyest fix for both would be drive the car in a straight line about a foot or so, then without allowing the road wheels to steer in the slightest remove the steering wheel and re/fit it were you require it to be straight,
observe the safty precausions if it has an air bag ( not the missis )
regards malcolm
regards malcolm
Xaccers
- x 185
Or take it to a tyre place and ask them to re-do the tracking (which will make your tyres last longer too and save money on fuel) while ensuring the steering wheel is straight.
DIY sphere tool
DIY sphere tool
jeremy
You will be Ok if the steering wheel has never been removed. The trouble is that to do the job properly the rack needs to be centred -- which is best done by measuring its movement, setting it straight, then checking/removing and replacing the steering wheel in the correct position.
Having done that then the front wheels should be adjusted so that they are each at the correct angle to the centre axis of the car.
Incorrect tracking will show up as uneven tyre wear - excessive toe out - inside edge wear, toe in - outside edge wear.
The car will only feel right if all the linkage is set correctly.
jeremy
- x 1240
