I suffered a big loss of engine oil the other day on the motorway. Got the car recovered and have just traced the leak to the headgasket right behind the cambelt. With the car running you can see oil start to weap out at quite a rate.
I know this should really be a new head gasket job, but as the car is on 175k, and is worth very little, I am reluctant to do this.
Any bodge fixes I can do to patch the leak?
Chemical metal?
Oil leaking from head gasket XUD9
- x 94
uncle buck
- x 10
I don't think there is much chance of fixing the leak other than doing the Head Gasket. I'm pretty sure that there's a main oil gallery in the position you mention, the gasket must bee letting oil past...if its not coming from the camshaft oil seal as malcolm pointed out.
Out petrol 1.4 Xsara had the same problem & someone had attempted a fix on that with copious amounts of silicone, needles to say it hadn't worked. The amount of time they must of spent carefully positioning & shaping the silicone would have been better put towards replacing the gasket.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
Ed
Xaccers
- x 185
Changing the gasket is more time consuming than expensive.
Jim and I replaced the head on Cassy in about 2 days parked up outside my house in the street
DIY sphere tool
DIY sphere tool
- x 1240
- x 94
