de-cat pipe
davethewheel
de-cat pipe
Unread post by davethewheel »
i've seen a de-cat pipe that would replace the cat on my xsara diesel estate, my question is do you think it is worth doing, there is nothing wrong with the cat that is on there i was just thinking if it would give me a bit more performance it would be worth doing, car has only got 72bhp so any small gain would be useful :)
x 94
Unread post by citronut »
defenatly is/dose/did on my xantia 1.9TD, besides that they give good money for scrap cats
regards malcolm
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
its a new betting syndi cat e
cats scrapping :lol:
XantiaMan
x 18
Unread post by XantiaMan »
Wont make any noticeable difference on a non-turbocharged diesel engine to be honest.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
x 94
i belive it should make a diferance on a disesl, as even a brand new diesl engine pumps out soot partcals, which will foul the cat up, hence restric the exhaust gasses escaping
regards malcolm
davethewheel
even if i only gain a few bhp it will still be worth it, unfortunately the pipe i thought id found isn't a cat replacement pipe it to repair the pipe after the cat.
i suppose i could get someone to cut the cat out my old xantia had this done.
ralph
Unread post by ralph »
The snag is the Xsara diesel was never made without a cat, so all replacement exhaust sections will be made to fit with a cat pipe.
You'll be able to get non-cat exhausts for 306 and ZX diesels, but whether these will fit a Xsara is a different matter.
I recently had my cat replaced on my Xsara. It was a "distress purchase" (the old front pipe had rusted through at the manifold) so I didn't have time to look around for a through-pipe alternative.
It goes no quicker with a new cat however...so I can't believe they get that clogged up.
2000 Clio 1.2 8-valve
Couple of Merc 190s
2009 petrol Focus
1998 Xsara TD, 293K - gone but not forgotten.
205s, 405, ZXs all loved and crushed.
Stunned Monkey
Unread post by Stunned Monkey »
Diesel and petrol cats are different animals (hah! see what I did there? ;) ) with the diesel one basically being a particulate trap, and can legally be removed because particulates aren't tested at MOT. The Xantia HDi cat is part of the downpipe and always splits at the elbow just upstream of the cat. I had mine welded back together and gutted the internals. Then it split just south of the cat :twisted: - if I had the time, I'd sort out a proper bit of pipe instead of what it is now - a resonance chamber. I noticed marginal improvement in performance and mileage.
Martin
Old Faithful: Silver V-reg Xantia HDi Exclusive, died due to tin worm @ 259k miles
New Faithful: Silver W-reg Xantia HDi Exclusive, 169k miles and counting...
Previous: Various BX's, XM V6 24,
Venturi Atlantique 300, Alpine A610
oscarloco
Unread post by oscarloco »
Performance gains are low, about 1 or 2 hp. But you gain on fuel economy. The downside, noise. My ZX is LOUD, specially in the 5000-6000 RPM region and with the K&N filter and cold air induction.
Oscar Lopez
'94 ZX 2.0 8v petrol (restoration to its former glory on its way after being neglected by stupid Ex)
