**SOLD OUT** Cheap Torque Wrench heads up.....
uncle buck
x 10
Unread post by uncle buck »
Tesco Direct have a Draper ½" drive Torque Wrench reduced to £15 whilst stocks last....seems a decent price if anyone's after one.
>> Torque Wrench <<
Have a look around the site....there may be more offers...
Apolgies for posting in this section but I thought by posting it here more members would get to see this offer. :wink:
Cheers.
**EDIT**
All sold out now.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
meexi
Unread post by meexi »
every little helps :lol: :lol:
2004 C3 XTR HDI 16V 92bhp
2004 Xsara Picasso Exclusive HDI 16V 110bhp
1989 Peugeot J5 Hymer B694 2.5td intercooled 8v 96bhp
x 94
Unread post by citronut »
but what torque range has it though
regards malcolm
Xaccers
x 186
Unread post by Xaccers »
Will let you know thursday when I pick mine up along with a new iron.
DIY sphere tool
x 94
spose the iron is to iron out the creases in all the pages in those XANT manuals, TEA HE
regards malcolm
handyman
Unread post by handyman »
Looks a bit flimsy to be accurate. Cannot see how you can combine a head of a normal ratchet onto a sprung loaded torque arm and expect it to be up to the job? Wonder how accurate they are and if they can be adjusted?My Snap-On ratchets, which have similar heads, always need re-adjustment or servicing and I only use them occasionally. :shock:
My old Britool torque wrenches still do the job after thirty-five years and are easy to recalibrate. :roll:
Always thought Draper tools were a bit second rate. [-X
Handyman
thorter
x 41
Unread post by thorter »
Probably the same as Argos 701/3887 or several other badged versions. I have owned a Clarke version for a good few years.
It covers most 1/2 inch bolts, and is of adequate far east quality. I use it mainly for wheel nuts.
Fred
Old-Guy
x 24
Better than nothing
Unread post by Old-Guy »
Surely, even an inaccurate torque wrench is better than a wild guess? :)
Much better than a sheared fastener? :D
x 94
Re: Better than nothing
Old-Guy wrote:Surely, even an inaccurate torque wrench is better than a wild guess? :)
that will depend on how often you are going to use it or bin it after a couple of gose
regards malcolm
handyman
You could always use a spanner of known length and a spring balance. You could then calculate the force generated in Newtons (NM) or footpounds ftlbs to give you an accurate measure of the torque applied to the head of the bolt or nut. :shock:
Handyman :roll:
uncle buck
x 10
Sold out now anyway.
thorter
x 41
You can get the Argos version for £14.99.
Fred
Xaccers
x 186
Picked mine up today.
Seems very solid and the manual states its rugged and designed for workshops.
It also mentions the calibration service offered by draper.
DIY sphere tool
uncle buck
x 10
Can't be bad for £15 quid can it :)
It's the 3001A model & the range is 30 - 210 Nm (22.1 - 154.9 ft-lb)
