R reg Xantia blower fan not working ??? Help !!!
Steviebax
Unread post by Steviebax »
Hi all.
My wife was driving our R reg Xantia 1.9td back the other day, when the blower just stopped.
I've checked the fuses under the driverside and the all seem good but l'm getting absolutely nothing from the sliding switch. The heater still works fine as l can feel the heat coming out but no blower.
Anyone any ideas ??? I've heard strange stuff about ignition switches, relays, etc etc
Can someone give me some basic pointers so l can try and fault find this ??
The Xantia has aircon and the slide switch goes from auto to max. There was no previous indication, it simply stopped completely half way home.
Any help more then welcome.
Cheers in advance.
Xaccers
x 185
Unread post by Xaccers »
Mk1 Xantias are prone to this, and there's a relatively easy fix.
If you do a search for blowers you'll find a big thread on the matter.
Basically the current for the fan goes through the ignition switch, and after 7-10 years it burns out so won't power the fan.
Normally it is still able to provide enough juice to switch a relay, so you install a relay off the ingnition switch and a 12v feed from somewhere else.
Bingo you get your fan back :)
DIY sphere tool
x 8175
It is a good idea to do this mod even if the switch has not failed yet. It will and this mod takes all the strain off the switch. Also, not a good idea, apparently, to hang lots of keys off the switch.
Also have a check of the connections (the heavy ones particularly) on the blower speed controller under the blower motor and accessible on removal of the cardboard cover in the passenger footwell. These carry heavy currents, heat up, loose their temper and make a bad connections that gets worse over time until they fail. They'll look hot and bothered if this is the area of the problem.
Xaccers
x 185
Yup that's what happened to Cassy's even after doing the mod.
Have had to tweak the connectors in the brown plug to make better contact, all nice and cool now :)
Jim, would it be an idea to have the big blower thread (with the photos on how to do the mod) stickied as it comes up regularly?
DIY sphere tool
x 8175
Xac wrote: Jim, would it be an idea to have the big blower thread (with the photos on how to do the mod) stickied as it comes up regularly?
Excellent idea Xac :D
Steviebax
Thanks for the help guys.
I've just be looking on the forum for that ignition mod and l found some piccies but there in french. Anyone got the english version ???
If l use a multimeter whats the procedure and voltage l need to know to check the power across the blower ???
By the way - l'm good at mechanics but an absolute numpty at electrics !!!
So a ' dumb ass guide ' to the ignition fix would be very much appreciated.
Steve
x 8175
Steve,
This is a good threadto start with and contains links to the others.
I've made it sticky.
Basically, put a meter on the thick red and black wires in the brown plug that goes to the blower speed controller under the blower and look for 12V there. Those are the 12V feed from the ignition swiitch. The other thick red and black wires on single connectors are the connections to the blower motor itself from the speed controller.
Steviebax
Thanks Jim.
I'll give that a go tomorrow. I think l'll also give the heated rear window a go - see if that's failed aswell.
By all accounts l should do the ignition switch fix.
Step by step instructions and/or pictures would be great.
Steve
Steviebax
Hi again.
I've found a step by step instruction to the ignition fix.
I'm going to use a 40amp relay to sort it - but what kind of wire do l need as l assume it will be pulling high voltage.
Any one got a spec l can use in my local wire shop ???
steve
Clogzz
x 40
Unread post by Clogzz »
20 Amps wire, 4 mm circumference, auto electrical wire from car tackle-and-trinket merchants, or equivalent from electrical suppliers.
Did the modification with 20 Amps wire nearly 10 years ago, and it’s still going. :D
2002 C5 2.0i AL4 239,000 km 76372389
