the problem is when you depress the pedal at about halfway down the pedal gets a bit firm and then get easier as you press it further almost as though it's got two positions in the travel, the clutch is hydraulic any ideas as to whether this sounds like an actual problem with the clutch, or a problem with the master/slave cylinder
xsara clutch problems
davethewheel
my xsara which has the Citroen dw8 non turbo diesel engine has got a slight problem with the clutch, when i bought the car it came with a bill from the main stealers for a replacement clutch that was at around 99k car is now on about 127k.
