I started a clutch change today on my 95 TD SX, and had to stop and re-think my approach...
Firstly I cannot get the gear linkages off- Haynes manual says simply- "Prise them off with a flat screwdriver" All I seam to do is tear the rubber inside them...
Secondly I can't see how to get the pin out of the lever arm.
Does anyone have any ideas?
Awaiting your thoughts.
Martin
Problems with Xantia's clutch change
Martin Beevers
95 Xantia 1.9TD SX - Now sold
- x 8187
Hi Martin,
I know your problems well
Don't attempt to removed the rubberised ends of the gear linkages and only pull the solid ends off. It's OK to leave the rods dangling as you remove the 'box. They can be tied out of the way if need be.
Best method I find to disconnect the balljoints is to roll them over to the very edge of their movement, exposing as much ball as possible and then levering them a little more with a small pry-bar. So often they come off with finger pressure when right on the edge.
If you have torn the rubber, you must replace the rods although a temporary repair can be done with superglue!
The clutch release pin: Remove the spring, douse the pin and housing in Plus-Gas and attach a pair of Mole Grips pointing vertically up and tightly attached to the exposed part of the pin. Take a hammer and tap firmly on the jaws of the Mole Grips to drive the pin forward and out. This works better than trying to twist the pin out.
On the subject of the release lever and shaft, replace the top and bottom nylon bushes. They cost pennies from a stealer and make a big difference
Martin Beevers
- x 94
Martin Beevers
- x 8187
Yes, not a problem at all Martin. I've extracted a gearbox with the linkages dangling from it with no worries. As Malcolm says, it do't matter where as long as you only disconnect the solid ends and not the rubbery ones!Martin Beevers wrote:Cheers Jim,
Do you suggest I disconnect the linkage's further back? I mean the next ball joints down. If that makes sense...
The official tool for popping off the linkages is a fork-shaped device, hence Malcolm using a spanner for the job. I've used the same method in the past but prefer now, my short cranked pry-bar or if the Weetabix has gone down well, just fingers.
Martin Beevers
Martin Beevers
Got a new linkage from the local dealer and was amazed to find Citroen have modified the connectors.
It had buttons you could press to release/connect the ball joint.
However, when everything was all back together I found that when I turned the front wheel forward the opposite wheel turned backwards.
Help, I can't fathom it out. I'm a bit stumped. I just can't see what's gone wrong.
- x 94
Martin Beevers
Martin Beevers
- x 8187
Martin Beevers
