TD LH engine mounting
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Does anyone know how this unit is fixed to the car?
x 8263
It's screwed into the inner wing John, into a captive nut. It needs a special tool (ideally) to engage with the cut-outs in the top of it...
Then, as the BoL might say, unscrew it. Only thing is, corrosion may have it stuick fast and the captive nut might start to pull. I think (memory again) that you can get to the underside by looking uder the wing and if you can get a bit of Plus-Gas going on it, I'm sure it'll make the job easier.
A meaty webbing strap as used for to shift oil filters might do the trick to remove it.
jgra1
(Donor 2021)
x 36
thanks Jim :D
x 1476
LH or RH??
To me the LH one is on the end of gearbox, the RH one is around the cambelt area. Although LH as you look at the engine is the cambelt one....
Maybe I'm just over pedantic!
jgra1
(Donor 2021)
x 36
Sorry Rich I was going to say offside, then drivers side , then ended up with LH side :)
Cambelt end..
my dad tried to lift his 306 using the engine as a jacking point :shock:
result - one torn-apart mounting :(
x 94
Unread post by citronut »
some of the O/S/UK drivers side/ RH side ( when sitting in car )LH side ( when under the bonnet/ hood engine mounts do have a nut on the under side, which you get at under the afore mentioned inneer wing
regards malcolm
jgra1
(Donor 2021)
x 36
:D thanks Malcolm
