C5 Wheels Non centre thingy
mooseshaver
How do I describe the problem of the C5 Wheels not being centred to a tyre person so they can balance my wheels right?
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
jgra1
- (Donor 2021)
- x 36
UFO
- x 1049
Solid centre wheels, most decent tyre fitters & dealers should have an adaptor for their balancer to allow the wheel to be attatched to it through the stud holes rather than throught the hole in the middle, it shoud also be able to adapt for 3,4 & 5 stud wheels as the old AX chicago had 3 stud alloys with solid centres.
den169
mooseshaver
Thanks everyone, I took it to HiQ near me, and they said they had the adaptor.
Will find out on Saturday as I shall be motorway driving
Gone cars.
Gone cars.
birstall
Mooseshaver
The first time HiQ did mine they were spot on. That was after taking them back to Kw1kfit 3 times and them still being wrong.
I went to HiQ again recently but they had to have 2 attempts to get them right this time. If you're still getting a slight vibration at 60 to 70 mph, take them back again.
I stood with the fitter while he was doing them the second time and explained that they are very difficult to get right. We agreed to get the balance figures down to about 0 to 2 rather than just below 5.
Most fitters I've come across aren't careful enough when they put the wheels on the adaptor. You need to tighten all four bolts and tighten them in the correct manner and sequence for the job to be right. Like Den169 says, forget Kw1kfit: they don't seem properly trained to do the job, in my opinion.
Current: C5 HDI Exclusive Saloon
Past : C5 HPI Exclusive Saloon
C5 HPI Exclusive Est
Xantia 1.9TD VSX
BX 1.7 TZD
Xantia 1.9TD VSX
BX 1.7 TZD
Onlinemyglaren
- x 5615
mooseshaver
Still got vibrations. I can see my arm wobble at 70, passangers can feel it through the seats.
at 60 its less, but I can still feel it. Will go back again Monday and try again
Gone cars.
Gone cars.
- x 1423
My experience is that it is not the balancing itself that they get wrong, but the centering of the wheel on the adapter.
I have seen 2 or 3 different types of adapter, the worst is a universal one where the 4 studs can be moved in and out ofr different PCD wheels.
I think even on the adapters with fixed studs, some seem to be easier to use correctly than others.
Last time I had a vibration that would not go away, it turned out to be a tyre (or maybe 2) that was going out of round at speed. Only cured by a new set of tyres.
mooseshaver
I went back, and they asked at what speed the vibration stops. I never thought of finding that out, so they advised me to drive faster without getting a speeding ticket and push through the vibration. So I have found out the vibration starts at 55 and stops at 95. Could it be anything else other than unbalanced tyres
Gone cars.
Gone cars.
den169
mooseshaver
I've been back, they had a look and told me it had shed a weight.
So from wed afternoon to Sat morning it had managed to lose a weight. Despite not being near any kerbs or speed bumps.
Will try and see tonight if its cured.
Gone cars.
Gone cars.
mooseshaver
DickieG
- Monaco's youngest playboy
- x 38
