Start on around 50% and work your way up.
At 100% the engine "hunts" until the fuel warms up, but is fine as soon as you pull away.
If your glow plugs are on their way out, you may need 2 cycles of them being activated, in which case, replace the plugs.
Normal advice is to replace your fuel filter after about 500miles, and then as normal, checking to see how clean it is when you change it.
If 6000 miles produces a mucky filter, change it at shorter intervals.
Most vegetable oils (like rapeseed and soya) will have your car smelling like a chip shop, while corn oil apparently smells like popcorn
DIY sphere tool
