the front suspension on my xantia tends to drop when i start the car and makes a noise whilst dropping??????????
If the cars been parked up for a couple of days it then start with no problems.
What can be the problem?????HELP
RUNNING 100% BIO
xantia t reg 99 model 1.9 turbo D Suspension Issues
xantia 1.9td 1999
addo
- Sara Watson's Stalker
- x 95
jgra1
- (Donor 2021)
- x 36
- x 8175
jgra1 wrote: the groaning, mine does this when I walk away from it.. I think its upset about the way its treated or something..
Miy estate does that (at the front) sometimes John. Rather a bizarre sort of Urrrrrrrrrrrrrgggggg noise as it falls
If the back sinks on start-up, that does have a cause or three. It usually indicates your main accumulator and/or rear corner spheres are getting on a bit and could do with replacement. You'd may as well swap the antisink sphere if it's old but this is not often the root cause.
How long is your regulator tick interval? Anything less than 30s and you have a flattish accumulator.
addo
- x 95
I believe it's the bushes labelled "2" in the attached diagram, from Citroën Service. My background is (originally) in things that make pleasant enough noises, so the ears are dialled in to quantifying a new sound.
As these bushes are squeezed tight around the bar, and often are dry (always, in the case of rubber) they will vibrate as the height changes and the bar rotates, transferring this resonance to the body panels where their saddle clamps are mounted.
Using a little (conventional) brake assembly grease or rubber grease would almost certainly quell the sound for a while - but I rather like it.
Regards, Adam.
Regards, Adam.
jgra1
- (Donor 2021)
- x 36
hmm makes sense Addo..
I like the effect it has on people who get out out of car
Jim, I think my ticking is 20-30s but wil check....
The amount of HP pressure needed to get the car to normal height first thing, is enough to stall the car or make it harder to start.. glowplus were all fine a few weeks ago.. could be the cold and veg oil..
John
John
- x 1453
That noise is nothing to do with the rubber bushes. It's one of the pipes associated with the front anti sink valve vibrating against the body - in certain circumstances if the AS valve is closed but the suspension height is not correct then as the AS valve opens the suspension height corrects, but I think the AS valves chatters, and this gives rise to the noise. I think there was a service bulletin from Citroen to try and deal with it, but AFAIK it was never really successful. I suspect that it occurs due to leakage in the rear suspension which drops the system pressure before the front height has the chance to correct. My estate does it - and many estates seem to sink at the rear - don't know if the rear susp cylinders are more prone to leakage on these??? I need to get around to some car maintenance, and new rear spheres is one of the things, to see if that will help stop the rear sinking.
xantia 1.9td 1999
xantia 1.9td 1999
citrojim wrote:jgra1 wrote: the groaning, mine does this when I walk away from it.. I think its upset about the way its treated or something..![]()
Miy estate does that (at the front) sometimes John. Rather a bizarre sort of Urrrrrrrrrrrrrgggggg noise as it fallsAs you say, nothing to worry about at all but worth a strut lube although that may not fully cure it.
the ticking from the regulator once the car has completely settled, i would say is around the 10/15 second mark. What is an 'ACCUMULATOR'...???
Any pics would really help. Thanks
Xaccers
- x 185
Open the bonnet, stand in front of the car, and look down between the engine and the radiator, you'll see a green sphere.
That's your accumulator. It keeps the pressure up when the pump isn't running, which is important as you need it in working order for braking if your aux drive belt snaps for instance.
About £20 to replace.
DIY sphere tool
DIY sphere tool
