3 relay fan wiring.. pug / cit and now chevy ;)
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Hi all :)
Can you look at
http://3.bp.blogspot.com/_2fj8MH_LeQ0/S ... y+diag.jpg
I have redrawn and simplified the wiring for the series / parallel wiring on our fans.. I want to fit a twin fan set up to my camper...
I am ok with it except the wire coming out of switch position '2' needs to energise all three relays, but in position one, it needs to energise just the first relay.. as I have drawn it, it will energise all relays whether on 1 or 2 position..
as I write I think the answer is a double pole switch or something...
will explain more later :lol:
John
Clogzz
x 40
Unread post by Clogzz »
You could use a three-position switch with an ‘off’ position, where a diode feeds relay 1 on the 3-relay high-speed position.
jgra1
(Donor 2021)
x 36
hi Cloggz, sorry I was using an off,1,2 switch..
but I can see the diode you've added :) looks like it will do the job, thanks
jgra1
(Donor 2021)
x 36
the switch is off, 1, 1 and 2 so no need for a diode although I brought 4 from Maplins as I felt guilty buying one for 25p ;)
its not as neet as citroen, work well though :lol:
http://3.bp.blogspot.com/_2fj8MH_LeQ0/S ... +speed.JPG
Clogzz
x 40
Oooh ! The lovely contraption ! :lol:
Is an off-1-1&2 switch a common car electrics switch, or did you cobble it ?
Will you have to watch the gauge to switch, and haven’t got thermostatic switching ?
4 diodes for £1 won’t go astray; one day they will come in handy to repair, or to make a bridge rectifier.
jgra1
(Donor 2021)
x 36
Cloggz that took me ages ! 30 mins at least!
switch came from Demoon tweaks, was quite suprised to see 1 and 1and2 ..
it even has a fan pic on it ;)
Have digital temp gauge too as dont trust the chevy one, wil work switch manually for now...
another pic in next few days
