I'm almost done fitting this to the SX estate, but need to know how the "brain" is strapped down in the console.
Can an obliging soul pop their oddments tray for a look, and report back?
There is a knockout panel in the carpet, slightly larger than a matchbox and adjacent to/covering a threaded stud. Is it fixed off to this with an M6×1 flanged nut, or just held onto the carpet with a cable tie (as per the originally unused plug)?
Hope someone can assist!
Thanks, Adam.
Quick Xantia II Question (Cruise Control) - Grovel Added!
addo
- Sara Watson's Stalker
- x 95
Toby_HDi
- x 3
Toby_HDi
- x 3
addo
- x 95
Toby_HDi
- x 3
addo
- x 95
The cruise control is a really simple unit. It basically feeds off the VSS signal, and regulates suction to maintain that reading. If the plugs are fitted, you'll be able to install it. Broken units are quite repairable, too - it's usually just solder joints expiring.
The computer is found in a bunch of PSA cars, as is the vacuum pump assembly. What varies are the brackets for mounting a couple of bits.
Peugeot had a facility for manual cars (D8 models of 406) with cruise; there was a pair of series switches on the brake and clutch. I think you could do similarly and splice in a series switch on the clutch pedal, to correspond with that on the brake controller which interrupts the cruise circuit.
I'd say have a little probe around, and if you can find your vacuum pump plugs cable-tied near the horn, and the console plug for the computer - it's all ready to rock.
BTW, has anyone been able to resolve the original question?
I'll be happy to reciprocate with a full "how-to" for anyone tackling this in future...
Regards, Adam.
Regards, Adam.
Stempy
From memory when I had my centre console out I think it's attached to an upright metal bracket, if I remember I'll have a look tomorrow to confirm unless someone beats me to it.
Lexia ponce
Lexia ponce
addo
- x 95
Would anyone be able to check this mounting suggestion and confirm/debunk it?
Looks like the cruise box is duff - I've got onto this thread, but don't hold out massive hope for my DIY prospects.
The "send it away to America for repair" option may yet be cheapest!
Regards, Adam.
Regards, Adam.
addo
- x 95
- x 8172
Good on 'yer Adam, for fixing the ECU
There's a good article in this months Citroen Car Club magazine, the Citroenian, on cruise control with a good, simple technical description of how it all works. It's written for the XM but I believe the Xantia is very similar.
If you've not seen it, let me know and I'll scan the article for you.
I have some info on the Crusie Control in my library of MK1 Xantia manuals. If you'd like the full circuit and wiring diagrams let me know. According to the layout diagram, the ECU should live (on and RHD car) right below the drivers seatbelt reel at the very bottom of the "B" pillar, just behind the crossmember (i.e. in the same position the intruder alarm occupies on the opposite side).
Stempy
Right, I've just been out to look at the cruise box on the V6 and is is bolted in an upright position onto an L shaped metal bracket, so where your box is bolted to the chassis, that part would be bolted to the upright part of the L and the bottom of the L is then bolted to the chassis where you have it.
Lexia ponce
Lexia ponce
addo
- x 95
With Stempy's description, I can reasonably identify P/N 6547 GT as the support bracket - confusingly labelled here as item 11:
Jim - I know my compatriot Pottsy is still keen to locate the (donor) cruise ECU in his MkI estate retrofit. We've sourced the factory wiring diagrams (courtesy of an AussieFrogs lurker) but there are not a lot of "hands on" Xantia people in Australia. He's about 600 miles away, which sort of stops me from just dropping by to help - but I can easily pass on your location tip.
Here, the cruise can be a licence saver. You get these amazing straight roads in the middle of nowhere and the involuntary reaction is to unthinkingly increase speed - not good with our heavy penalties! Driving an 83 Fuego in the photo.
Regards, Adam.
