Laguna Key Cards
reflex
Laguna Key Cards
Unread post by reflex »
Hi All,
I have a 53 plate Laguna and the Lock button is unresponsive on both key cards. The Unlock works fine.
This means I have to lock the car from the inside.
Is this a known problem with the keys?
Does anyone have any suggestions or know prices on how much i would expect to pay to resolve the problem?
Ta
telderv
Unread post by telderv »
Dont know of any problems but was recently quoted £185 for replacement of lost key
reblack68
Unread post by reblack68 »
The buttons will need resoldered. It's straightforward but tricky as soldering jobs go. I'm not sure where you'd go to find somebody good at soldering but I'd guess it won't be a Renault dealer.
Richard
Care of a 1994 205 D.
uncle buck
x 10
Unread post by uncle buck »
Key card problems are very common.
Obviously the first thing to try is the battery...replace it with a new one.
If a new battery doesn't cure the problem it's probably just a bad solder joint as reblack68 mentioned....the card will have to be cut open to gain access to the insides to fix it.
http://www.keyrepair.co.uk/ are well recommended within the Renault circles.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
reflex
Thanks guys, most appreciated :D
