forgot to check my haynes and now cannot get to it...
Could someone please outline the procedure for changing xantia hdi fuel filter? I've done the job before but have forgotten the proceedure. Thanks.
urgent xantia hdi fuel filter
mattpc
Xantia number three is..
HDI Exclusive Estate Cat C
marsalek
- x 19
On the 109 bhp engine there is usually Bosch fuel filter. You have to undo two fuel pipes leading to the filter cover. Press the green clip and slide them off. Then you can drain the diesel from the filter by opening the valve at the bottom of the housing. Then turn the cover anti-clockwise. I usually help myself with a spanner in one hand and the other hand turns the cover itself.
Karel
Karel
