New Key Programming On 2006 Citroen Relay
anit999
Unread post by anit999 »
I need a spare key for my 2006 Citroen Relay. The only key I have at the moment is the flip type blip 2 button remote key. I am either going to buy another flip type remote key or a standard transponder key with no buttons. But the dealer wants about £40 labour to program it and they need the van there too. Is this something I can do myself? Does anyone have any instructions to do this?
The Citroen Relay van is identical to the Peugeot Boxer and the Fiat Ducato so maybe the key programming is by Peugeot or Fiat methods?
Is it possible to reprogram used keys? Here is one I found on ebay:
http://cgi.ebay.co.uk/CITROEN-RELAY-REM ... .m20.l1116
Also I found this new transponder key on ebay:
http://cgi.ebay.co.uk/Citroen-Relay-Tra ... .m20.l1116
would a dealer be able to program that.
I have the key code card with the electronic and mechanical code.
x 1044
Unread post by wheeler »
You need dealer diagnostic equipment for this job & you definitely cant reprogram a 2nd hand key. in fact on this system (its a fiat system on this) all keys for the van must be present for the coding procedure, any that are not there at the time can never be reprogramed again to the van.
