blower problems some body must know!!
tgrfc
Unread post by tgrfc »
Hi Everybody,
last resort!!
Today i have changed the blower motor on my car, checked all the fuses and i still have no blower at all.
This seems to have slowly died over the last 2 weeks, first it started working normally but over the last 2 weeks its has slowly died getting gradually slower and slower like it was running of a little battery, now i have nothing. if it is the ignition switch how easy is this to get to and change? i am a completly new to the electrics of this car.
Oh ye its a S plate 1.9td xantia opps sorry forgot that bit.
any ideas????
many thanks in advance John
marsalek
x 19
Unread post by marsalek »
Hi, the ignition switch makes trouble only in Mk1 (before cca March 1998).
Karel
x 8389
Welcome to the forum John :D
Yep, that'll be the classic ignition switch problem as Karel says. You'll also likely find your heated rear window has stopped working too and testing the HRW is a useful aid to the diagnosis.
There is a modification to bypass the duff part of the ignition switch using a relay. It's easy enough to do.
Colin (Admiral51) did this mod recently and he posted a good article about it. Have a little search and all will be revealed :D
tgrfc
Thanks for the welcome and very quick responses guys!
I think the HRW is still working but will try tomorrow to be sure.
If its any help this only seems to have started happening since the alternator belt snappd and i had it repaired 3 weeks ago. failing that i think the mod is the only way.
cheers
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Hi John
the mod itself is very straight forward to do but i cant seem to find the post i put up after i did it will try and look again tomorrow try searching for fan mod by RichardW there are pictures and diagrams plus lots of input from Cloggz et all
Colin
andmcit
x 30
Unread post by andmcit »
Clogzz
x 40
Unread post by Clogzz »
Don’t find the Admiral’s thread, but here’s something like it:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=23827
Mandrake’s thread:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=21372
RichardW’s diagram:
http://www.geocities.com/tricky992002/fanmod.xls
Maps of before and after modification:
Image Image
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Just check the 35a RELAY above the Throttle pedal under the dash...
Ive a HDI 110 Exclusive xantia here, which didn't have a blower...
So with ignition on, and blower on max, I removed the GREEN 35a relay, and then pushed it back in and HEY PRESTO the blower burst into life...
Switched it on/off a few times, ignition on/off a few times, and it carried on working.! A slightly easyer thing to try before going all into the ignition switch mod....
rgds
Paul
A very sad...
1994 XM 2.1 d auto
andmcit
x 30
This is the standard green type of relay? There's a good many under
there on my Xantiae, which one are you referring to? Did you just use
the same relay or swap it?
Andrew
citroenxm
Fallen Hero
x 70
Its the only green one DIRECTLY over the pedal Andrew, remove the small cover trim, and the relay is clipped in too! I just pulled it out and pushed it back in, so yes I used the same one...
It worked!
Rgds
Paul
A very sad...
1994 XM 2.1 d auto
Mr Matthews
Unread post by Mr Matthews »
citroenxm wrote:Its the only green one DIRECTLY over the pedal Andrew, remove the small cover trim, and the relay is clipped in too! I just pulled it out and pushed it back in, so yes I used the same one...
It worked!
Rgds
Paul
I too have 3 relay points under my acc' pedal, same as andmcit, but only one socket has a green relay in it, the other 2 are empty (don't know what they are for!).... I pulled out the relay, it was in top condition ie(no blackening), I put it back and still no blower?
Life is hard.
x 5672
It worked!
Rgds
Paul
Work it in and out of the socket a few times, perhaps even clean the contacts with a bit of fine wire wool and some degreaser (Meths) to remove any corrosion or surface contamination.
Spray a drop of contact cleaner into the socket too..
It is also possible that the contacts are `frozen' - they weld themselves shut sometimes, particularly if overloaded.
Mr Matthews
Ok, I will try that tomorrow, by the way, could the fan relay be at fault also... if so, is it the purple one in the engine fuse compartment... also, while I'm on here, should I check the Bitron's and (where are they situated)?
Life is hard.
x 1459
Unread post by xantia_v6 »
Mr Matthews wrote:Ok, I will try that tomorrow, by the way, could the fan relay be at fault also... if so, is it the purple one in the engine fuse compartment... also, while I'm on here, should I check the Bitron's and (where are they situated)?
I think that the green relay mentioned here is only applicable to Mk2 Xantia, so not your car.
When you mention fan relay do you mean the radiator fan relays? as they are the only fan relays on a Mk1 Xantia, but have no connection to the heater blower, or do you have a problem with the fadiator fans also?
I don't think that the bitron can stop the heater blower from working, as it controls the radiator fans.
Have you actually measured the voltages at the ignition switch or the blower motor?
Mr Matthews
xantia_v6 wrote:I think that the green relay mentioned here is only applicable to Mk2 Xantia, so not your car.
So what other purpose is the green relay under the pedal for, I have 3 green sockets of which one has a green relay!, I'm just curious as to what they are for?
xantia_v6 wrote:When you mention fan relay do you mean the radiator fan relays? as they are the only fan relays on a Mk1 Xantia, but have no connection to the heater blower, or do you have a problem with the fadiator fans also?
No, no problem with the rad', you have answered my question and I now understand ( I thought Citroen had several relays that were connected to the heater/blower :P )
xantia_v6 wrote:I don't think that the bitron can stop the heater blower from working, as it controls the radiator fans.
Short and to the point :)
xantia_v6 wrote:Have you actually measured the voltages at the ignition switch or the blower motor?
Not with a volt tester or anything, but as none of the connections looked disturbed or blackened, I just dismissed that notion.
Life is hard.
