Hi all,
This is my 1st post on here and I have one question:
The pressure sensor in my c5 is faulty (valve broken), can I just have a new one fitted, or does the computer have to be told that there is a new one?
Many thanks,
c5 tyre pressure sensor
- x 1045
KevMayer
You can have standard valves fitted when you next change your tyre. The trick is knowing which sensor is faulty.
I have two of my sensors replaced with standard valves and the only thing I get is a warning on the display saying '1 tyre pressure sensor missing' even though 2 are missing. I don't know why it only reports 1 missing.
This alarm appears when you reach 25 mph and then disappears so isn't much of a problem.
Citroen main dealer told me a new valve with sensor would cost around £65 on top of the cost of a new tyre if I have the tyres replaced at the dealers.
cheers, Kev
cheers, Kev
Cheers, Kev
Fella
Tyre Sensors
C5s can be reprogrammed to ignore tyre sensors - my local dealer did it for free.
pete_wood_uk
But they are quite handy sometimes - I was sceptical after purchase, but the other week mine warned me of a slow puncture in a rear tyre (it had dropped from 36psi to 30psi) which I certainly hadn't noticed on a brief routine walk-around the car. Wheel removal and inspection found a self-tapper embedded in mid-tread, which if left could have caused a catastrophic blow out.
Score one for pressure sensors!
Cheers
Pete
PS: And if anyone posts saying "You should check your tyre pressures every day", then all I can say is Get A Life - or rather, since you've got time on your hands, have some of my life...
Cheers
Pete
Xantia HDi 110 Excl Estate 140k
C5 HDi 138 Estate
C5 HDi 138 Estate
fred1
Try this link for replacement sensors.
http://tyre-equipment.co.uk/acatalog/Pr ... alves.html
They are about £25 +vat and inc postage.
Regards
John
Regards
John
