Megane rear hub nut
matt615
Megane rear hub nut
I want to check the brake shoes on my 1998 Megane. The Haynes manual says that I need to remove the hub nuts to do this, and that I should use a new hub nut on refitting. Is it necessary to use a new hub nut? If so where would be the best place to obtain one? Thanks
citroen7
matt615
