Whilst out driving, my Xantia 1.9 TD started overheating badly. Pulled over and found there was no water left. Got it AA'd home, filled it up and discovered that the water was pouring out the front grill and could see water dripping from the radiator and it look pretty corroded. Someone recommended k-seal, so I tried it. Left it running until the fans came on about four times, but the coolant just kept pouring out.
So I bought a new radiator. After I had fitted it, I left it running, in the correct manner with a header tank and bled all the air from it, until the fans had come on and gone off a few times. Everything was fine. The temperature behaved normally and there was no leaks or drips.
Just to be on the safe side I took it for a spin.
For three or four miles it ran beautifully, then all of a sudden the power dropped and it started blowing blue smoke out the back. Then as quickly as it started, the smoke stopped and the power came back. It ran fine for a couple of hundred yards and started again. All gauges read normal.
Got it home, lifted the bonnet and all around the expansion tank was covered in coolant and there was a hissing from the cap. When I went to remove the cap the pressure felt very high so I left it and haven't been back to it yet.
Does anyone know what could be causing this?
Is the coolant issue linked to the power loss and smoke problem?
Any advice would be appreciated as I've just about had it with this bloody car.
