AX getting less lemony
Stempy
Unread post by Stempy »
So I bagged a throttle body and idle stepper from a 1.4 AX. Seems they are the same as those on the 1.0 but I'm hoping they might have modified them from the ones fitted to the 1.0 as TPS wear seems to be a common problem. The TPS itself is a different colour so maybe that means something.
Anyway, fitted it this evening and it's running much much better, no flat spots or hunting, I think the constant jerking might have taken its toll on the engine mountings though as it's a bit clunky.
Next job is new discs and pads then SWMBO can start using it for shopping etc.
Lexia ponce
