i have noticed that my espace is taking longer to start from cold. it sometimes takes 4-5 seconds of cranking before it fires up(before it would start as soon as the key is turned)
a bit of history about the car, it had a replacement head in april when the head gasket went after it lost all its coolant due to a hose blowing, and also cracked the head in the process(new glowplugs were also fitted then)
i tried to see if there is voltage at the plugs when the key is turned but nothing(this is strange because my brothers 98 espace also has not got any voltage at the glowplugs either when the key is turned)
all help grateful, it had an oil change in april but not fuel or air filters
best regards Mark ? ? ? ? ?
98 espace diesel getting harder to start !! help
billy_bottle
mjr001
