Cat replacement for Xantia 2.0HDI
daver74
Unread post by daver74 »
Hi, I've got a '00 Xantia 2.0hdi and it's exhaust pipe has rusted through before it meets the cat (in fact, right on the bottom bend after it comes down from the manifold and then goes straight).
I'd like to avoid replacing the cat, but can't use another piece of pipe because it's on the bend.
I know that for the 1.9td the cat can be replaced with a straight through section, but is there one for the hdi? Does anyone know of one so that I can avoid paying £95 + vat for a new cat?
Thanks for your help - great forum.
KP
x 27
Unread post by KP »
You may be best going to an exhaust fabricator and getting them to see if they could make you something up as it should suffice but the 1.9td im sure is different as its for a DW10 engine not an XUD9 so the routing would be off.
x 94
Unread post by citronut »
look your car up on BOSALS web site, you should be able to work out if there is a straight through pipe like there is for the 1.9D/TD
regards malcolm
reblack68
Unread post by reblack68 »
I don't think there is. As far as I know all HDi Xantias had a cat. The pipe for the TD isn't intended as a decat pipe, it's intended as a direct replacement part for cars that didn't have a cat in the first place.
Richard
Care of a 1994 205 D.
marsalek
x 19
Unread post by marsalek »
Hi daver74,
I am afraid, there is no replacement pipe from the manifold to the cat for that engine. Guys here in Germany buy a piece of bent pipe in a plumber store (sorry for my english) and weld it in place. It is also good to repair the connection to the pipe at the other end of the cat. Some of them open the cat, take out all what is inside, replace it with a piece of a straight pipe and close the cat again. Do not know, if the missing/lower pressure resistance behind the turbocharger does not damage the turbocharger.
Karel
x 94
i dont know if the lower presure can damage the TURBO , but removing the cat sure dose make emmmm goooooo better, even a brand new diesel engine chucks out particals, cats arnt designed to let these sort of particals through, so it clogs them up inturn resticting the exhaust gasses from escaping
regards malcolm
daver74
Ok, I suspected there wasn't a direct non-cat replacement (for the HDI). Thanks for your help.
f00lzz
Unread post by f00lzz »
Thats an easy fix for the specialist exhaust people.. loads of them about and some will do the change for free !!!! if you give them your Cat (they are worth money
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
