xantia suspension
xantia suspension
Can someone tell me how I can tell what type of suspension I have e.g. hydractive or not. I have six spheres as far as I can see. I got told I had hydractive so I put on the three at the back which has improved suspension but what will happen if I have fitted the wrong ones. I am desperate as I have also ordered the front ones now so need to know quick so can change order if needed
xantia suspension
Hi
Thanks for the reply It is a sx model facelift but got told it was hydractive when got spheres. They seem to work alright but are they going to do any damage and also affect the handling as I tow caravan with it or is it better to change them for the proper ones
The car will be a lot firmer than it was orinally intended to be designed by
Citroen; it won't actually damage anything but it'd help to fit the correct
spec spheres. The rears may not show up the difference of the wrong one's
fitted but I'd expect due to the greater weight borne by the front they
would. If the firmer spheresare at the back the car would be tauter with
less suspension fluid transmitted into the suspension arms so it may even
make the car less wallowy when towing!
In reality, the car is probably not a mile off a car with the correct spheres
fitted that are a bit flat; there will be more strain on the other joints and
suspension components that will not appreciate the extra work they've been
asked to do so I'd get the correct spheres and reorder the right pair for the
pending fitment one's!
I'm sure someone here would buy your recent hydractive spheres!
I'd take them off your hands!
Andrew
Andrew
You won't be able to fit the rear suspension accumulator where the anti sink sphere goes as there will be no 4.5mm hole in the sphere to put the pipe in. Although you would be able to put the anti sink sphere in the wrong place!
If it is an SX then it will not have the hydractive suspension.
The easiest givaway is as others have stated, the pipes. These pipes going to the suspension units, front and rear are 8mm spanner sized fittings on the standard car and 17mm on the hydractive, so there is a big difference.
Please do not rely on the switch! We had a guy that was convinced that he had a hydractive Xantia because of the sport switch down by the gear lever, so we sent him a full set for the hydractive, well he spent about 3 hours trying to find a home for the extra spheres and eventualy phoned us to ask where they went, after about 15mins of discussion, I realised that the sport switch that he was talking of was for the auto gearbox, not the suspension, on the later auto Xantia they had the fancy electronic gearbox that had a sport mode, I only realised this when he mentioned the fact that it was 1999 petrol auto and remebered one of my past Xantia's. I often wonder who has this now. anyone here maybe? It was a blue petrol auto with an LPG conversion T429 VAV I think. I bought it new in 1999 and had the gas fitted at about 3'000 miles, this made it quite a cheap car to run, sold it on in 2003.
Martin.
Martin.
