Working on an old Triumph I think it was....
I seem to recall this happening before where I got loan of a spring compressor that couldn't clear the cover mating surface and reach the recessed valve springs.
It was just like this one http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=008 and no matter how I configured the spring end, it just wouldn't safely work for me.
Another type I'd tried didn't reach in far enough so there must be several different kinds available and I need to be sure I get the right one.
This one look like it will clear the edge and reach down to the springs but I can't see how the collets can be accessed when it's on - it actually looks like a common G-clamp in the picture. http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=012
This looks the right shape but will have to ask about the reach length and depth to be sure. http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=016
If there's anything else I need to look out for that I haven't mentioned or if you have any suggestions at all, please reply.
Differing spring compressors
jgra1
- (Donor 2021)
- x 36
hi Mike
mine is very similar to the last one.. I had to get it to service a 16-valve zetec head last year.
One thing about mine, I can't use the lever to squash the springs.. the lever doesn't have enough leverage... I have to get the compressor 'shut' and then use the threaded section instead....
will send a pic later...
to be honest, if i can get my valves in and out before Monday (depends on head warpage) then If you cover postage i will throw you mine
or bike up and grab it ..
Although I expect you want yours out now not in a few days...
another option:
pop to machine mart, buy one, then put it straight on ebay.. you wont loose much?
another option:
- x 94
MikeT
- x 232
reblack68
That type is for replacing valve springs or valve stem oil seals without removing the head. It's a bit of a fiddle usually but a lot less bother than taking the head off. If the head is already off you're best to use the normal kind.
Richard
Care of a 1994 205 D.
