When the engine is warm it won't start for about 10 seconds and when it does start there is a big cloud of smoke, it does not happen when the car is cold.
Whan i was looking around i found 2 vacum solenoids (?) close together which 1 is disconnected, plus i found another device which i think is supposed to be connected to one of the solenoids.
The first pic is the 2 solenoids, the right side one is disconnected,
http://www.aqua.org.il/modules.php?name ... ic_id=8470
The second and third show the UFO device behined the engine which has a hose coming all the way to the right side solenoid and is disconnected.
http://www.aqua.org.il/modules.php?name ... ic_id=8472
http://www.aqua.org.il/modules.php?name ... ic_id=8471
xantia 1.9l td, problem with starting and smoking
wonderd
Xantia 2.0L 16V manual trans. 96
Xantia 1.9L TD 99
Xantia 1.9L TD 99
admiral51
- (Donor 2026)
- x 391
Hi
not sure if this will help a great deal but..........................
my 1.9d will start on first turn of starter whereas my 1.9td will take at least 3-5 turns when hot unless i follow the following
1.turn ignition on and put in keypad code
2.wait for preheat light to go out
3.turn ignition off and repaet steps 1+2
4.when pre heat light goes out count to 4 and start and it fires up with 2 turns of cranking whether hot or cold
Citrojim did explain to me that the difference between the 1.9d and 1.9td starting is due to the compression ratio but im sure he will elaborate if ive got things wildly wrong
i beleive the cloud of smoke will be unburnt fuel due to the cranking of the engine and not firing so nothing untowards there
Colin
Colin
wonderd
- x 94
- x 1240
MikeT
- x 232
Have you checked the glowplugs are individually 100% working? Have you tried priming the fuel before cranking?
The two solenoids you mention are to control the cold start device (flying saucer as you call it which leads onto the back of the fuel pump) and the EGR valve (which is an insult to the internal combustion engine IMO).
It is common for both these solenoids to fail and in the case of the EGR system, that's a good thing IMO. Although the EGR valve sticking open is not good and I don't know how you can test for this without dismantling it.
The cold start device is operative by default and causes the engine to idle about 1100rpm. As the engine warms, the solenoid is operated and brings the idle down to normal so it should be obvious if yours is working or not.
Xaccers
- x 188
I'm sure I read several times on here there being a known cause for the engines not to start easily when hot.
DIY sphere tool
DIY sphere tool
- x 8422
Absolutely correct Xac. All diesels I've had fitted with the BoschXac wrote:I'm sure I read several times on here there being a known cause for the engines not to start easily when hot.
My theory centres around the low compression ratio (lower still if the HG has been done as pointed out by Peter.N.) which is not conducive to good starting, hence need for glowplugs every time on a TD and that hot diesel in the pump being thinner than cold diesel does not pump with such high pressure. Also, the intake air will be hot from a heat soaked turbo and intercooler and will be less dense and contain less oxygen. All will have an effect.
As I say, just a theory.
wonderd
- x 8422
- x 1493
wonderd
Xaccers
- x 188
When were the glow plugs changed last?
DIY sphere tool
DIY sphere tool
wonderd
jeremy
- x 3
Does the engine crank fast when hot? What can happen is that the compression pressure rises and the engine actually cranks slower when hot than cold - and doesn't start as well.
Worth trying with the lights on to see what happens - it could be due to too small a battery, tired battery, poor earth or battery connection or starter main feed - or even starter.
jeremy
