Hi everyone, could someone please tell me what the orange warning light on the dashboard means?
I have a Xantia 98 1.8 LX Estate Manual.
I bought her about 1 month ago and don;t have the manual to check what the light means - it's a weird shape on the far left of the console, with what I can only describe as possibly an orange engine and a black K shape in it!? (excuse my artistic impression of it!)
Can anyone enlighten me?
Thanks!
Pete
Warning light help!
- x 8234
That's your Engine Management Light, also known as the "K" light. So-called because the K is an approximation of the schematic symbol for a transistor so the full symbol of a transistor inside an engine is telling you the Engine ECU has a fault or faults stored.
You will need a diagnostics session to determine the cause and to enable you to make a repair and put the light out.
Is the engine showing any obvious performance issues? A clue to rough running may enable the problem to be revealed without formal diagnostics.
If you have the radio code, it is worth disconnecting the battery for an hour to reset the ECU. This may extriguish the light if the original cause of the light illuminating has been cleared.
- x 5626
- x 8234
myglaren wrote:I thought it meant the engine was Kaputt.
Pete, if you should be anywhere near me, pop over for a quick (free) diagnostics session.
Secondly, if you live anywhere near the route between here and South Somerset, something could be arranged. I regularly travel up and down that way, usually the A421/A34/A303 or the A420/A361.
p3dro
