xantia aircon not working after cam belt change
greencruiser
I have 97 Citroen Xantia 1.9td, I recently had the cam belt changed & the aircon has never worked since. The light on the dash doesn't light up once the button is pressed, the engine drop's a little to indicate that it has switched on but the air doesn't get colder. The air con worked fine before the cam belt change! Does anyone have any suggestions:?:
- x 94
- x 8189
I agree with Malcolm, take it back if it was done by a garage!!!
However, it may just be something as simple as the Hi/Lo switch connector has been disturbed on the receiver/dryer (the cylinder near the ECU box with the sightglass on it).
It is often helpful to pull this connector to make removal of the engine mount easy...
greencruiser
- x 8189
It's on the top side of the receiver/drier bottle (the cylinder with the sight-glass on top of it. Normal location is just in front of the radiator on the left-hand side (as you look in the engine bay with the bonnet up) adjacent to the ECU box above the wing. It'll be a 4-way connector.
MikeT
- x 232
