Making a damper pulley puller
Yes, place your time and money saving tips here.Nothing illegal or dangerous please!Motoring related only please.
MikeT
x 232
Unread post by MikeT »
This post relates to removing the damper pulley which drives the auxillary belt. It is necessary to remove this pulley if you're going to change the cambelt which sits behind it.
Firstly, you need to remove the 22mm bolt and spacer securing the pulley to the crankshaft. Then refit the bolt minus the spacer.
To make up a puller, I used two 8mm bolts and the bracket from an exhaust clamp.
It's best to use two equal length 8mm bolts but these worked for me just the same.
Fit the two bolts through the exhaust clamp bracket into the pulley holes by several turns to ensure a secure fit.
By backing out the pulley bolt which pushes against the clamp bracket, the pulley slowly but surely pulls itself out with ease.
x 8300
Mike, that's excellent :D
Many thanks for posting it up with pictures..
MikeT
x 232
My pleasure!
citroenxm
Fallen Hero
x 70
Re: Making a damper pulley puller
Unread post by citroenxm »
Just goes to show, when we work it out the Bloody french REALLY know how to do things!!
Ive always seen those two threaded holes but never sucessfully managed to make a puller out of something!!
Fantastic stuff! Ill not forget this now, certainly now theres a lot less XUDs about.
Anyone noticed the HDi pullt is very slack on the crank once the bolt is undone??
A very sad...
1994 XM 2.1 d auto
x 8300
citroenxm wrote: Anyone noticed the HDi pullt is very slack on the crank once the bolt is undone??
Yes, it worried me at first!!!!
dnsey
x 19
Unread post by dnsey »
Not as bad as the later one with the 'adjustable' keyway - I fail to see the point in keying it at all in that case!
