The throttle is sticky when releasing the pedal and the revs will stick at about 1300 before very slowly dropping to 900.i have had a look at the housing on top of the pump and it appears to be the spring under the linkage that is not returning properly as the cable itself goes slack.
Is it possible to replace this particular spring by removing the linkage if so how straight forward is it or am i looking at something complicated and expensive
Cheers
Colin
