Suspension rattle since fitting bush
dnsey
x 19
Unread post by dnsey »
I fitted a new front wishbone bush to the Xantia yesterday. All went well, apart from the usual struggle to press out the old one, and a slightly barrelled new bush.
Since reassembly there's been an intermittent clonk / rattle which I cannot pin down. Sounds very similar to a dodgy droplink, and occurs in similar circumstances (one-sided bumps), but I've checked both links and the rest of the suspension components, and all is OK. The bush has settled a little, but is still secure, and I can't provoke the noise by violently shaking the front up and down. Can't find anything rattling either (e.g. exhaust).
Any ideas, anyone?
x 1240
Unread post by Peter.N. »
Have you actually disconnected the drop links to check them? I have just changed one on my XM and it felt as solid as a rock - until I disconnected one end.
