Fastener Identification
MikeT
x 232
Unread post by MikeT »
I would be grateful if anyone has any experience of this strange (to me) nut and whether standard tools will grip it or if I need to buy a tool, what do I ask/look for exactly?
I'm tempted to jam on a deep socket but I don't want to round it off or damage my socket so I then thought of using a pair of mole grips or similar but there's not enough swinging room for those.
Any advice gratefully received.
AndersDK
Unread post by AndersDK »
Looks like a Torx socket is what you need.
There are a few variants of torx sockets and keys according to purpose. Some have a fine pattern with a large count of tooths others have a more course pattern. Looks like the latter is the one.
Unfortunately a standard socket will have a 6 or 12 edge pattern, while the Torx usually have an 8 edge pattern. So it might not be do-able with a standard socket.
But if you dont try, you will never win ... 8)
Anders (DK) - '90 BX16Image
XantiaMan
x 18
Unread post by XantiaMan »
Looks like a multi sided nut so a normal spanner could work, some cars use the same type for big end nuts.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
andmcit
x 30
Unread post by andmcit »
I've seen these on turbo's and manifolds as a deterrent anti tamper
fastening; of course there's every chance you can buy just the tool
for the job which kind of defeats the objective in the first place.
I'm sure no conventional fastening socket/wrench will be safe to use any
kind of torque with and jamming a socket on may make removal a whole
lot worse than it currently looks.
Andrew
MikeT
x 232
Thank you kindly for your suggestions gentlemen :D
I should have mentioned there are no sharp teeth on it like a torx and the relief is quite shallow not to mention the small size considering the force I'll have to use to break the corrosion. I'll see if I can source a socket Monday, as you say, I have to try something.
Yes, it's on the turbo, the only one of three bolts that have this nut and it's the bolt that fixes a support brace to the block :? which is the only reason I want it off.
x 94
Unread post by citronut »
i have managed to undo this type of nut with a multi point socket out of desparation in the past,
they are called TORX as allready mentioned
regards malcolm
dnsey
x 19
Unread post by dnsey »
Best thing is to take a 'rubbing' of the profile on a bit of paper to a decent tool supplier. Whatever it is, one socket won't cost a fortune (famous last words...)
MikeT
x 232
With all respect, doesn't a Torx only have six points?
I think, because of the 12 points (teeth?), it's something I've never heard of before - a Triple Square or ZXN.
See the silhouettes here for examples.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
I recently came across these nuts on the exhaust manifold of the CT Turbo estate Jim and I broke for parts.
I've just checked for fit on a few that I saved and found that a good quality (ie Facom is a closer fit than Halfords Professional) 10mm 12 point socket/ring spanner or a Torx 16 socket fits equally as well.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
XantiaMan
x 18
12 point should be a normal socket or ring spanner, the same type of nuts are used on many exhaust manifolds/turbochargers, Rover's use the same design nut but in 10mm format and they come undone fine.
2017 Fiesta ST
MikeT
x 232
As expected, no tool sellers have heard of Triple-Square and none of them stock torx sockets either.
I'll try other tools as suggested. Thanks lads.
x 94
all the motor factors i use sell TORX SOCKETS internal and external
try this link, or just do a google search for TORX SOCKETS, this is the first result i found
http://www.toolspot.co.uk/product/7pc-3 ... le-blister
regards malcolm
x 94
PS.
the fine type are called splin drive sockets or keys and the coures ones are TORX, both types have been around for quite a few years now
regards malcolm
MikeT
x 232
Cheers Malcolm, I'll go with the above suggested tools which I currently own first, otherwise I'll have to buy the spline sockets - which I can order locally, it's just they didn't have any in stock - though that online link is a good price for the set. :)
MikeT
x 232
Well you live and learn, eh? :lol:
As advised, a 10mm ring spanner fitted nicely so I don't see how it's got the reputation of being an anti-tamper nut :P
