My 1999 2.0 110BHP HDI xantia has started making a pinking noise again under load.
Now last time this happened it seemed to be a n old clogged filter and after changing the fuel filter it was nice and quiet.... well it started back up and from reading other threads on here it looks like it might be an idler pulley as such I would need to renew the timing belt, pulleys and water pump just to be on the safe side.
My question is this much different from the old XUD TD 1.9 as I’ve done a hand full of them without too many issues but I’m concerned that there may be other issues doing this on the HDI
Also has anyone got any ref numbers for ordering the full kit rather than separately
Jay
HDI timing belt harder to do than 1.9td ????
To me it sounds much like the standard HDI injector working noise.leepasifull wrote:My HDI makes a pinking type noise, but it stops making it as soon as the revs go over 3250. The noise doesn't get worse under extra load (or more throttle)
Is it likely to be timing belt related?
It's a 110BHp HDi with ~177k on the clock.
Mind you the HDI injectors opens/closes on a pressure source around the 1200 bar work pressure, which is indeed an incredible pressure to control ...
Meaning its a completely normal noise phenomen on a HDI type engine.
Anders (DK) - '90 BX16Image
