I have a 1998 'S' Reg 2.2TD Grand Espace RXE, that has just failed its mot.
I am not bothered about most of the mechanical failures e.g. track rods end, drag links and a damaged rear spring, but she failed on excessive amounts of metered smoke.
The average reading was 4.04 1/m whereas it should have been under 3.0
Is there any obvious common fault that anyone could pinpoint? EGR valve for instance? Not even sure if I have a EGR valve on a 2.2DT?
I read somewhere that a good hard drive can sometimes clear any carbon deposits?
Any help or suggestions would be greatly appreciated
Cheers
Rob
